mlts22
Nov 17, 2016Explorer II
Windshield washer stuff contains methanol. Very toxic and will cause permanent blindness, since it makes formic acid in the body and turns the optic nerve into plastic, which cannot be reversed.
For fresh water tanks, I use my Spec's discount and use the bottom shelf vodka. I blow out the lines, add booze and run it through all faucets, then blow the lines out again.
For the grey/black tanks, I empty the tanks, then squirt some Dawn dish detergent to sit there. Soap + water has a markedly lower freezing point.
Disclaimer: I live in Texas, where at worst, it might get into the 20s for a few days. In a northern area, I would not chance it -- I'd run RV antifreeze through the lines, and for the black/gray, I'd just dump a bit more of that.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
