mike-s
Nov 19, 2016Explorer II
rjsurfer wrote:RV antifreeze uses propylene glycol. The concentration (an therefore freezing temperature) may vary by region. Around here, they sell 1:1 (50 percent) mix, which is good to -20F, so you get 1/2 gallon of propylene glycol per gallon of antifreeze. But, it's intended to be used as provided, not diluted.
As I mentioned, sure I can use a couple of gallons of RV antifreeze in each 1/2 full tank (6 gallons antifreeze total) but carrying and resupplying them is a pain.
I'm just wondering if there is better more concentrated antifreeze that I could use instead, let's say a gallon or less?
You said you had 38 gallon tanks. If you add 2 gallons of 1:1 to a half full tank (19 gallons), you'll end up with about a 1:20 mix. A 1:5 mix (add over 12 gallons per tank) gets you +20F. That 1:20 mix you wanted - that won't do squat to keep things from freezing, maybe lower the freezing point a couple of degrees, so why even bother?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
