babock
Feb 07, 2020Explorer
time2roll wrote:It does't really run in a PWM mode other than to limit current so it isn't really the same thing as a PWM controller. It is still doing its DC to DC conversion at all times.groundhogy wrote:MPPT only functions in bulk mode then moves to PWM for absorption and float.
So.. PWM, with its switching the higher voltage on and off extends battery life and removes sulfation, while MPPT does not? MPPT results in shorter battery life?
Is there an MPPT charge controller with a boost? Mode? Boost mode is for cleaning off sulfate?
During absorption it is in Constant Voltage mode. It can still deliver higher current that the max current of the panel which is the drawback of a PWM controller. You only get the max current that the panel provides with a PWM controller.
An MPPT controller is essentially just a DC to DC converter. If you have panels wired at 100V putting out 10A for a 1000W, trust me, you will be putting in more than 10A in absorption mode.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
