wa8yxm
May 12, 2018Explorer III
First. You have the 2nd best RV antenna already there is only one upgrade to the antenna and that is to add the WINGMAN" about 50 bucks or less and 10 minutes once you get to where you can reach the antenna. You might want a pair of slip joint pliars in your pocket when you go topside. or a multi-tool. you may or may not need 'em.
For the best amplifer.> Sensar Pro also by winegard this replaces the wall plate and it is
Power inserter for the amp in the antenna head
Adjustable 2nd pre-amp.
Signal seeker, multiple modes
Signal strength indicator
Audiable signal strength indicator (Optional)
Cable switch
Station I'm watchin gi over 25 miles out SOLID SIGNAL as I type
Other stations are farther out Over 40 miles. Likewise solid signal.
There is no such thing as a Digital Antenna. A Digital antenna is a standard UHF or VHF/UHF antenna with a higher price tag. At the antenna it's all RADIO.
Cable switch
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
