LarryJM
May 12, 2018Explorer II
MNtundraRet wrote:
I hate to bust your bubble here, but I have been using a Radio Shack adjustable in-line RF amplifier (2 to 10 dBs of additional gain) since 2007.
It connects to output side of Winegard amplifier and straight to the television on RG6u coaxial cable. It gives me up to 20 dBs gain (adjustable from 12 to 20).
I used to have the Winegard III with Wingman, but converted head to Winegard Razar after headwinds bent the old head.
My typical range is 125 miles (clear day) to 150 to 200 miles at night or cloudy conditions. Over-power is rare since you can either cut gain, or move antenna off direct aim on strong transmitters.
You can check my old posts here for more information, if the archives have been straightened out since last year. ;)
Well I guess you can put me into the Doubting Thomas group and from all I know your results are sure not typical nor do they conform to the physics concerning amplifiers, noise, typical UHF ranges as I understand them. As the above post mentioned that must be some unusual trasmission towers since the line of sight for an antenna 5000 feet high is only 86miles and then you have to consider just the signal attenuation for the mandated extra low power transmission limits over those extreme distances. In fact the LOS for an antenna 10,000 ft (almost 2 miles high) is only just over 122mi less than you stated typical 125 mi range you quoted.
IMO your post definitely needs the footnote that "RESULTS NOT TYPICAL NOR SHOULD BE EXPECTED"
Larry
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
