mlts22Explorer IIJan 12, 2015Best fittings for water heater bypass valves?On winterizing, I noticed the cold water valve (part of the three valve array for bypassing the WH) was leaking around the crimp clamp. Since I always use a breakage as a way to upgrade to something ...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
Related ContentWater Heater Check ValveWater Heater bypass valve.Atwood water heater problemWater heater fitting?Water Heater Replacement Recommendations
