bkirkpatrick wrote:
westend wrote:
Best is pretty subjective. I see that most US based sellers sell a regulated bulb. That may have better longevity as the current is controlled at the fixture. As long as the components of the regulation circuit are durable and there is no RF interference, that could be considered a better lamp. I chose to use the Asian unregulated panels in warm white. The cost is significantly lower and I've had good durability. I figured that < $2.00 a bulb gives me some leeway if they prove to be less than adequate.
Best is NOT subject in real world comparisons where members here have tried bulbs based on advertised specs and "sales pitches" only to find out that they are too dim or don't work. The "RF interference" is a moot point because 99% of people here are not looking at that. Just reply with what you have personal, first hand, experience with.
Brendan,
I put the "subjective" in there because price may denote best for some, made in USA may give peace of mind for some, regulated current may be best for some, lumen output may be best for some, and there is a list of things that can make different choices best for others.
My experience: I wished to illuminate my 22' trailer with LED's and was not going to use the original fixtures for a variety of reasons. I either built my own fixtures or reused 12v halogen fixtures I had at hand. My needs were task lighting over countertops, central overhead lighting, and reading lamps near bunks. I also put a fixture in the shower.
After reading some of the LED conversion posts on the Forum, I got a feeling that all LED lamps were not equal. In fact similarly constructed LED's are not equal from different vendors. Also, Kelvin temperature can also differ between vendors. Early on, I ruled out the more expensive regulated LED's because of potential RF interference and the probability that I could build my own lighting regulator if voltage wasn't adequate for the task.
I bought a few LED panels in different configurations from different vendors, mostly in "warm white. A majority of these were either SMD36 3528 or SMD48 3528. I also bought some "cool white" and those with 5050 diodes. What worked for me were SMD 48 3528 in overhead central lighting and SMD 36 3528 in reading lights, all of them in "warm white". Some of my fixtures have an etched lens (the reading lights and countertops) and the rest have a clear glass lens. The central overhead fixtures are doubled (two panels) and can be operated together or singly.
My power source can vary between 14.5V and into the 12.* range. It rarely reaches 12.2V. I've not had any failures of diodes, none of my LED's reach high temperatures, and I am very happy with the outcome.
Hope this helps.
