theoldwizard1
Apr 22, 2019Explorer II
loggenrock wrote:
Mother Benz is VERY particular as to oil used...
Buy the CHEAPEST oil that meets the spec. Yes, this requires that you read the owners manual and the back of the oil bottle.
The cost difference from the cheapest to the most expensive (that meets the spec) is huge and you will not see much, if any. performance/durability difference !
Full synthetic is not needed (unless stated in the owners manual). Stick with conventional or a blend. The exception is if you plan to park your rig overnight at below 0F and no block heater !
And changing your oil much earlier than recommended, is a waste of money.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
