valhalla360
Apr 23, 2019Navigator
road-runner wrote:The engine dying isn't the issue. Using incorrect oil results in clogging of the DPF, which costs a thousand or two to replace.
It's incredibly rare for modern engines to die due to oil issues (obviously not leaks or obvious abuse). Any oil that meets manufacturers spec is perfectly fine and you can expect the engine to last longer than the rig.
If it meets manufactures spec...it isn't going to clog the DPF.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
