CharlesinGA
Apr 25, 2019Explorer
Edit, Road-runner has good info..............
Forget all the Cummins and large diesel owners saying to use Rotella or other oils. its in warranty and you have to use an oil that has a spec number, on the bottle or the specification sheet for the oil that has the word APPROVED in front of it. If it doesn't, it isn't approved. Saying it "meets" the specs is not good enough.
Here is the master list of specifications that will link you to each spec sheet with a list of approved fluids. For some reason, the master list of oils for MB engines 223.2 is bad and hasn't worked for several weeks now. This list is revised several times a year, as are all of the spec sheets.
https://bevo.mercedes-benz.com/bevolisten/bevo-sheets-sort1.html
Your best bet is Mobil 1 ESP x3 0W-40 or Mobil 1 ESP X1 0W-30
Or.. Valvoline SynPower MST C3 5W-30
You will not find these oils in WAL-MART!!!!!!!!
Generally NAPA has these oils and runs sales on them a couple of times a year (the Valvoline at least)
229.51 is a little easier to find, Mobil 1 ESP x3 0W-40 or Valvoline SynPower MST C3 5W-40 (and several others).
Again, for a V6 Sprinter, you won't find these oils just anywhere.
Get a good filter socket, that fits properly, well worth the money.
https://asttool.com/detail_page.php?from_search=y&tool_number=M0284&offset=0&stype=bymanf&manf=Mercedes&category=Oil%20Change%20Products
Use a torque wrench and adhere to the torque molded into the oil filter cap. Make sure your o-rings are properly placed in the grooves, or they will blow out and destroy the engine.
Consider buying a Fumoto oil drain valve, no mess and you can stop the flow if your pan is not big enough.
https://www.amazon.com/Fumoto-F-106-LC-10-Lever-Engine/dp/B07D9FD27F/ref=sr_1_1?crid=3571TME3IAYZN&keywords=fumoto+f106&qid=1556250012&s=gateway&sprefix=fumoto%2Caps%2C141&sr=8-1
The F106 series is the correct one for the V6 diesel.
Charles
Charles
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
