Take a look at Extech... They are on the same level as Fluke in my opinion.
I personally have the Extech EX730. This is a meter that will do the 'normal' stuff, plus has a built in clamp that will read up to 800A AC or DC. It will record peak values (perfect for measuring inrush current). It also has a probe for measuring temperature (if you so desire). Back-lit display. Little soft belt-clip carrying case.
I've had that meter for about 11yrs now. I packed that meter all over the US on commissioning jobs in the mining industry (Electrical & Control Systems Engineer). I used it for motor testing, on UPS battery banks, simple troubleshooting, ect. A great product in my opinion. The only downside (on this meter anyway) is that it must be manually switched from AC to read DC, but that holds true with most meters anyway.
Found my model on Amazon for $131.
Take a look at their other meters as well. They have numerous multi-function units with built in clamps, as well as separate clamps. Find whatever you think would work best for you.
I'm not knocking Fluke, I have two on my work truck (787 and 175), and have had my hands on everything from the simple T5 to 744 calibrator to 123 scope meters. I just glanced at the Fluke website, a similarly optioned 325 is about $260, and a similar priced 362 doesn't have the same abilities (but you may find it good enough). I'm sure there are other models out there, so don't hold me to just those...
