- gboppExplorer
rk911 wrote:
gbopp wrote:
If you want quiet, get an oil filled heater. They take up more space but do the job.
Otherwise, get the heater you like. As said, they are all about 1500 watts.
Even the cheap ones.
our 1500-watt fan heaters are whisper quiet and take up virtually no space.
I stand corrected, thank you. I'll have to check them out. - mcheroExplorer
ksg5000 wrote:
Lots of opinions on what to buy ..
The very reason the question was posted. Lots of opinions/suggestions!
For those of you using electric heaters, make sure you don't overload your circuit(s). I strongly suggest people inspect their AC panels . I found a loose neutral connection on the bus bar that was starting to overheat turning the white insulation brown. Caught it before it fried the bus bar! Don't want to find out the hard way you have a loose connection. - LwiddisExplorer II750 watts keeps my TT warm but not my tanks. How are you warming your tanks?
- rhagfoExplorer IIIPersonally I hate portable electric heaters. We installed a Cheap Heat electric add on unit to our gas furnace. Not cheap to buy, but heats the basement also, provides 1,800 watts on 30 amps, and 5,000 watts on 50 amp. We also have an electric fireplace heater that will work well in really cold weather.
- ksg5000Explorer IILots of opinions on what to buy ... but running an electrical heater on lower setting often creates more heat because they tend to shut off prematurely running on high. Two heaters run on lower settings on separate electrical outlets will often generate enough heat to keep the RV warm.
- rk911Explorer
- wa8yxmExplorer IIII like the ceramic's because they are small.
Portable Electric Space heaters are unique in all of the electric/electronic world as they are 100% efficient. The Reason for this is that all losses become heat so since heat is the desired product they are 100% efficient
OH I know some folks will talk about the fan. but the fiction of moving air creates heat. So that's recovered
or the GLOW from a red hot element.. Absorbed by surfaces it impacts and converted to Heat.
So TECHNICALLY it makes not difference.
Now some.. may do a better job of moving air and that may make you feel more or less comfortable.. but they are all 100% efficent.
And 12.5 amps (1500 watts) is a bit more than I care to put on most RV wiring. THe wires (14ga) are up to it but the "Unibox" or "Quickbox" type outlets.. The connections are often NOT up to double digit current.
Two 750 watt on different circuit breakers.. Should be no problem though .(less than 10 amps per line). - pauldubExplorerI have a Vornado and it's about the quietest fan based portable heater around.
- gboppExplorerIf you want quiet, get an oil filled heater. They take up more space but do the job.
Even the cheap ones. - bgumExplorerWe use one of the small Walmart ceramic heater with fan. We run it on the lowest setting. It does just fine heating the airstream. It uses about 750 watts and with 30 amp supply we can run other items such as a coffee pot.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
