- jimbo4UTExplorerwow lots of great tips, thanks everyone. I had an oil filled heater and i never got even close to warm. I tried using a fan blowing thru the heater to get it to give out heat and that didn't work either. Really like the idea of using another heavy duty electrical line from the pole to inside and just run the heater from that one. Saved on the rig electrical lines, i would think and you can place it where you want to. Thanks again everyone
Jimbo - bikendanExplorer
gbopp wrote:
If you want quiet, get an oil filled heater. They take up more space but do the job.
Otherwise, get the heater you like. As said, they are all about 1500 watts.
Even the cheap ones.
That's what we use. no noise. - ppineExplorer IIIHeat in your trailer will help keep your tanks warm.
25 degrees is no big deal. - pianotunaNomad III
rk911 wrote:
pianotuna wrote:
Hi Lwiddis,
I replaced the furnace return air grill with this...It pressurizes the duct work and keeps the plumbing from freezing up. It is controlled by a mechanical thermostat which is tucked against the outside wall inside the kitchen cabinets.
got a link to share, pls?
https://www.walmart.com/ip/Holmes-HAWF2021-WMUM-Dual-Blade-Twin-Window-Fan/17133777 - Community AlumniLots of good advice here and good brands out in the market. I have a Holmes and a 1Touch, both 1500 watts. When one of them quits I will try a Vornado. I usually run one on low all night and have the furnace set as backup, the setting depends on the overnight low. Down to about 35 degrees the furnace may come on near morning. I have used 2 heaters at times when colder but placing them can be an issue and having 2 running is a concern for us. We have been out in nights down to the high teens. On those nights We open the kitchen and bath cabinet doors to warm the piping. I haven't had an issue with the tanks with these methods.
One thing I highly recommend is to run another heavy duty cord into the unit for one heater if the electric box has a 20 amp outlet. This takes the load off of the RV's circuits and makes it safer if two heaters are used. It is easy to do with slide outs as the cord can be passed by a seal. - pnicholsExplorer II
jimbo4UT wrote:
Would appreciate anyone who has a ceramic or other type portable heater to chime in and tell me what brand they have and if they feel it does a good job heating. My rig is a 32 feet Class C.
thanks in advance,
Jimbo
Here's what we use in our RV. It's an outstanding combination electric heater that simultaneously puts out both radiant heat and warm air heat.
We've had ours for years and have used it in our home and now use it in the RV. It's worth the wait until it becomes available again:
https://www.kmart.com/holmes-quartz-tower-heater-hqh320/p-006W060046311312P - rk911Explorer
pianotuna wrote:
Lwiddis wrote:
750 watts keeps my TT warm but not my tanks. How are you warming your tanks?
Hi Lwiddis,
got a link to share, pls? - coolmom42Explorer II
CA Traveler wrote:
We have 2 of the small cheaper 1500W ceramic heaters that are common to Walmart etc. They are easy to store and you can run 2 on high (25A for both).
I second this. Unless it's really cold, you may need only one. I've used one in a 25' trailer and it would heat up the place really fast. - pianotunaNomad III
Hi Lwiddis,
I replaced the furnace return air grill with this:
It pressurizes the duct work and keeps the plumbing from freezing up. It is controlled by a mechanical thermostat which is tucked against the outside wall inside the kitchen cabinets. - pianotunaNomad IIIMy preference is for no one type.
If there is a frozen compartment--a radiant heater is best. I've been able to meld the ice on the seal.
If there is a cold floor--electric heated carpets are best.
If there is room in the bedroom, a pair of oil filled, one on each side of the bed, may be the most comfortable.
If size is a concern, then fan based ceramics work a charm.
I keep a 240 volt incandescent bulb fed with 110 volts, on a mechanical thermostat beside my water pump.
To heat 100% electrically, replace the cold air return grill on the furnace with a twindow fan. In my RV that keeps a small amount of warm cabin air circulating through the duct work for the furnace, preventing plumbing system freeze ups.
My peak wattage in the deep cold is 7700 watts, and the continuous load is 5.4 kwh.
I do use my autoformer to keep the voltage up, so I get the full number of watts from my various and sundry heaters.
I've boondocked at -37 c (-34 f).
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
