joelc
Sep 24, 2019Nomad
I have a Vinyl roof and use Dicor. I would call them to see if they recommend it on Aluminum. One note about Aluminum. I had a Class A once that had an AL roof and it developed bad leaks and pin holes. Seems the manufacture installed the AL over steel without a barrier. That caused electrolysis in the AL causing failures. Be sure your RV does not have that issue.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
