Almot's avatar
Almot
Explorer III
Aug 07, 2014
Best stainless screws for wood?
Trying to figure out the best self-tapping screws for wood and particle board - it has to be STAINLESS dome head or hex head.
Have already used sheet metal screws to install a solar panel. Will add another panel but suddenly started having some doubts.
There are no stainless "deck screws" - you know, those with thread similar to drywall screws - that would have dome head or hex head. When I look at "wood screws" in places like Home Depot, the thread looks identical to sheet metal screws only partially threaded, with un-threaded section of shank.
Searched McMasterCarr, they have stainless "serrated thread screws for plywood" - with size, length, and head that I want.
Q: What would you use to install on the roof something that is heavy and should also resist winds, using #10 screws, sometimes in 3/8" particle board, sometimes in rafters under particle board? Sheet metal screws again, or serrated threads, or... ?
(I'm not asking about the right number of anchor points VS wind force, solar panel height etc - let's not go there, the panel will be horizontal or with very little tilt).
PS:
RV manufacturer for all the exterior used a regular carbonized steel sheet metal screws, metric - don't ask me why metric, probably they got a box on cheap from an automotive supply place. Some heads are corroding already.
  • You might want to check out 316 stainless material. 316 has molybdenum and is both stronger and more corrosion resistant than cheap stainless alloys. Places like West marine and Harbor Marine in Seattle have a whole selection of fasteners.
  • Try to stay away from Chinese stainless, not very good. Good stainless is NOT magnetic. Test it with a magnet.
  • I used stainless deck screws from Ace Hardware. Shape of the head is fine.
    Mine are Robertson drive (square)
  • There are stainless "deck screws" They come from Screw Products Inc, made from 305 Stainless. I buy the #10 X 3" & 3 1/2" in 5# containers. I also like that they come with the T25 Star Drive so that your driver doesn't slip in the head. Have been using them for 5 - 6 years.
    I especially like them because they don't corrode making it easy to take them out an reuse them. The reason I reuse them is because they're not cheap.
    I see from their web site they come in other sizes and they do mail order. SS screws Clicky
    I also bought smaller sizes from my local hardware store.
    I first started using them because I build a lot using the green pressure treated lumber - the chemicals in it will ruin standard deck screws so they weaken and fall apart. After a standard deck screw has been in green pressure treated lumber for a year or two, you can't remove them. Either you have to use SS screws or galvanized lag bolts.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Apr 20, 2024
