brulaz
Jun 25, 2016Explorer
The electronic accutire worked well for me except in the extreme cold (way below freezing)) after leaving it out in the truck over night.
Current one is a mechanical dial gauge with a hose extension that goes to 120psi. It reads and holds the max pressure; you reset to zero with a little button or use that to bleed the pressure down to what you want.
Similar to this one: http://www.homedepot.com/p/Accutire-Heavy-Duty-Dial-Tire-Gauge-MS5010/204488012
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
