valhalla360
Dec 18, 2020Navigator
Bobbo wrote:
An oil as a degreasing agent? Grease is just oil mixed in with a soap to make it firm.
No.
It's a bit more complicated than this but if you break a barrel of crude down, it comes in a variety of components that run from very thin and easily evaporated (ie: naptha) to very thick to the point of being almost rock hard (ie: asphalt)
In between are a wide variety of products of varying viscosity and evaporability.
By mixing a thinner product with a thicker product, it will soften or even liquefy the thicker product. It's technically not allowed but paving crews would often have a bucket of diesel and they would dip their shovels in it occasionally as it would dissolve the asphalt off their tools.
So yes, a petroleum products can be used to degrease. The problem with WD-40 in this application is it doesn't evaporate completely, so the remaining thicker products left after evaporation tend to catch and trap dust and grit.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Sep 13, 2021
