westend
Oct 17, 2013Explorer
Craig N Tammy wrote:I have heat guns but a hair dyer puts out about as much heat. Be careful on painted surfaces or plastic. You don't want to ruin anything. Also, 3M makes a caulk remover that works great for silicone or latex caulk. Don't know how it works on Dicor. Maybe someone around here knows what solvent to use with Dicor? The butyl sealant should just about fall off.
Thanks westend! When you say "use heat" are you referring to a heat gun (e.g. HIGH heat) or something like a blow dryer (low heat)?
Craig N Tammy
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
