nvreloaderExplorerApr 05, 2014Best Way??I have 4-Canadian SC6P-220w Panels with the following spec's, Pmax=220W Voc =36.60V ISC =8.09A VMP =29.30V Imp =7.52A Voc-coef =0.1281V/C Noct =45.00C 15A fuse rating/series Per actual meas...Show More
CA_TravelerExplorer IIIApr 06, 2014Wire size to the battery depends upon the distance. Use the wire size in the manual. Is the refer the only/best option for wiring? What about cabinets/closets etc?I thought you finished this project years ago???
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
Related ContentDometic 2-Way fridge repair issuesEasy way to remove slide topper?which way?Absorption fridge 2 way vs 3 wayReplaced landing gears and switch. Switch extends both ways
