Thanks for the info, Guys
Which of these types of connectors would be the best for combining the panel wires down to the CC, the wire size will be 10ga to the CC.
See info here:
http://www.ebay.com/itm/One-Pair-MC4-Type-PV-Solar-Cable-Y-Branch-Connector-FFM-MMF-TUV-/190782130077?pt=LH_DefaultDomain_0&hash=item2c6b80479d#ht_4103wt_1204
http://www.ebay.com/itm/3-Pairs-Solar-Panel-Cable-MC4-T-Branch-Connectors-Splitter-Coupler-Combiner-USA-/251364785056?pt=LH_DefaultDomain_0&hash=item3a86823ba0#ht_540wt_810
The wire run/length from the CC to the 4-GC batteries will be a max distance of 10' or less, and since the MS CC can use #2 awg cables, that is what I will be running to keep the losses at the minimum etc.
The reefer duct is the center point of the panel lay out and a straight shot down to the OEM electrical bay where all the wiring comes together etc, in this TH RV.
Ca Travler,
between family deaths, drawing a sheep tag (34yrs trying) + 4 other family members drawing tags and a full remodel (inside/outside)of the home front per orders from the better half, then drawing a prized Bull Elk tag (35yrs trying), + 5 family tags, (All works stops to fill the tags), all the inside stuff is stored inside the shop with NO ROOM to do anything, plus working 4+ months away from home, there don't seem to be enough time to do anything, if you know what I mean.
I am making some head way, now!!
Tia,
Don
