nvreloaderExplorerApr 05, 2014Best Way??I have 4-Canadian SC6P-220w Panels with the following spec's, Pmax=220W Voc =36.60V ISC =8.09A VMP =29.30V Imp =7.52A Voc-coef =0.1281V/C Noct =45.00C 15A fuse rating/series Per actual meas...Show More
time2rollNomadApr 06, 2014I agree, NO fuses needed on the panel side. Service disconnect maybe.The current is self limiting. You can short the panels and no harm done.More than two parallel technically needs a fuse.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
Related ContentDometic 2-Way fridge repair issuesEasy way to remove slide topper?which way?Absorption fridge 2 way vs 3 wayReplaced landing gears and switch. Switch extends both ways
