I have 4-Canadian SC6P-220w Panels with the following spec's, Pmax=220W Voc =36.60V ISC =8.09A VMP =29.30V Imp =7.52A Voc-coef =0.1281V/C Noct =45.00C 15A fuse rating/series Per actual meas...
Since no fuses are needed, What kind/type of electrical disconnects would you use on the panels or wiring so you could work on the wiring or system, if needed and not let the magical Blue smoke out or go for a ride on the electrical freight train?
Tia, Don
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
