CA_Traveler
Jul 30, 2021Explorer III
FWC wrote:Problem solved. As I posted install it in a vented box near the battery. 100V input voltage means you could have a 3rd panel later if desired. Need to check on the 290W spec. My controller is OK with overpaneling.
The Victron MPPT 100/20 is the 'best' MPPT Charge controller for your application. It IP43 rated, so fine for spray and splashes, but I would still put it in some kind of enclosure. Maybe a small Pelican box so you can easily open the lid for ventilation when it is working hard.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
