Sandia_Man
Feb 07, 2020Explorer II
With enough truck to properly haul your TT around, particularly at highway speeds, any of the WD hitches with integrated sway control should suffice. Those with less than ideal towing combos, whether it is due to not enough truck or poorly designed trailers, usually resort to Hensley or Propride hitches to achieve a sense of towing comfort while underway.
On the other hand, just because you have more than enough truck does not indicate you can forego a WD/SC hitch altogether, seen too many 350/3500 trucks crawling along the highway and still see their 30' TTs excessively swaying although they are towing well below posted speed limit. Properly set-up, TTs can be towed without noticeable sway, even when passing semi-trucks.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
