pirlbeck
Oct 18, 2017Explorer
Best winter storage procedure for Crown deep cycle batts??
Let me start this by saying I have tried to search this topic on here with very little results.
This is in a Lance truck camper, not that it should matter. It has a pair of Crown group 31 deep cycle batteries that were new last spring. It has a Progressive Dynamics 9200 series converter and the Trimetric 2030. The normal battery voltage while plugged in is 13.1 volts. I am trying to decide if I should leave the unit plugged in all winter or unplug it and disconnect the batteries. It is in a cold storage building in Iowa and temps likely will be below zero. One battery is pretty easy to access to keep an eye on the electrolyte level, but the other one is a real pain to access. What is the likely hood of boiling off much electrolyte at 13.1 volts if I leave it plugged in all winter?
Thanks!
Thanks!
