Almot's avatar
Almot
Explorer III
Jan 22, 2017
Better cable clamps?
Several nylon cable clamps cracked after two hot summers - can't say exactly how hot it was inside the closed trailer with 105 outside. The clamp is 3/8 by Gardner-Bender, the cable is a pair of #10 solar panel cables routed inside the cabinets. They are tight with two #10 cables, and I like it this way. Could've used 1/2" size. There is a bend/tension here, but several of them cracked, on the straight runs as well:
Is there anything better? I saw 1/2" plastic staples of a harder plastic, the weird thing is that they come with nails, don't have a nail gun and prefer screws for trailer:
  • Almot's avatar
    Almot
    Explorer III
    Rock - temperature explanations make sense. Varying temps together with tension in the clamp can do this. It can go from 75 to 35 in one day there.
  • X2 on the cushion/metal clamps.
    What people don't realize is all plastic clamps and including zip strips. There is a temperature rating written in small print on the package labels.
    I'm sure the RV manuf buy the cheapest ones without regard to temp ratings.
    I used zip stips to attached a canopy up North. When the temps fell I literally watched each and every one just crack open one by one. That is how 'I' found out about the high/low temp ratings on the labels.
    The better the temp rating is the more expensive the zip strip cost was.
  • Almot's avatar
    Almot
    Explorer III
    I wonder how they specify the size in those rubber coated clamps. Ex, 3/8 broken nylon clamps were pretty tight with two #10 solar cables. In cushion clamps is it 3/8 opening btw rubber jaws or you can squeeze in 3/8 max while compressing the rubber? Have to go to Home Depot and measure. Amazon have it cheaper and stainless though.
    Edit - ops...
    They don't have it in HD Canada.
  • Or you can use the staples you show and pull out the nails and add screws.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
