wa8yxm
Aug 03, 2015Explorer III
Good photo of a Sensar Pro (mine is black) Nice strong signal on carrier chan 15. I love mine.
Since my coach has a matrix switch (Box of many buttons) I mounted a standard outlet box in an area that i9s next to useless on my coach and mounted the Sensar Pro there.. Works greatr and easy to see when adjusting antenna.
One of my comnplaints against the JACK..
I was in a THOR class C trying to figure out how to get park cable to deliver to the TVs. (Found it) there is a 120 volt DUPLEX recpitacl in a cabinet with a wall-wart power supply plugged in (For the Jack Sure-Lock)
The Wall Wart hid the switch plate with the light, switch LED and antenna conneciton (jack uses it too)
I suspect but am not sure the Sensar Pro would work with the jack as well
But still Independent lab tests TRULY independent, done by another forum member.. Show the Jack can not beat the Batwing+Wingman even without the Sensar Pro inside. Best mod I did was installing the Pro.
I did a few other mods (mostly cabling) and now have one Rube Goldburg system Includes a pair of DVRs that can go OTA or Cable under THEIR control (Channel number decides) and a comnputer to serve up Electronic program guides..
All the advanced features that only our 100/month or more service can provide per the advertisers.... I got 'em.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
