- RJsfishinExplorerAdd the wingman to batwing 3, or replace w/ sensor 4
then add the sensor pro (pic)
IMO, the sensor pro is worth its weight in gold if you do much OTA tv. It'll save you 30 minutes of screwing around trying to find channels. W/ the sensor pro, you'll know right now if and where the watchable channels are, or if there even is any, and that's w/o ever turning the tv on. - GordonThreeExplorerwingman add-on and the sensar pro amp... or double check the wiring for your current antenna, could be it was wired wrong at the factory long time ago.
- stevekkExplorer
- Dick_BExplorerWe like our Jack. It is lighter than our original Winegard thus easier to raise and lower.
You could also search this Forum for `antenna' and search the results for words like `winegard' or `jack' or `HD' etc. - RoyBExplorer IIHard to beat this BATWING layout...
Roy Ken - Dutch_12078Explorer IIIWinegard's Sensar IV antenna plus their Sensar Pro power injector/amplifier is about as good as it gets for a mobile installation. If your existing antenna is a Sensar III, then the low cost Wingman add-on will update it to the Sensar IV specs. The Sensar IV and Wingman add-on are much more directional antennas than the Sensar III alone though, so finer tuning is required to maximize signal strength.
- SoundGuyExplorer
wbilotta wrote:
2001 Damon intruder with the original antenna. I'd like to find a better antenna. Any suggestions?
Better antenna than what? :h Hard to make any recommendations when we have no idea what antenna you already have.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
