JoeH's avatar
JoeH
Explorer III
Feb 12, 2021
Bidet attachment
Has anyone found a bidet attachment that will fit on either a Thetford Tecma ( macerator) or Thetford Aqua Magic ?
The tecma has the seat bolts that are on the vertical part of the "bump" so standard attachment doesn't work and the Aquamagic has the rear bump and a raised edge on the bowl.
  • frankwp wrote:
    The Blondell seat I have at home has a flat metal plate that bolts onto the toilet & then the seat is secured to that plate. It might be able to be redrilled to fit an RV toilet, but I can't say without taking the plate to the toilet to see.
    If we had our old rig with ceramic toilet and horizontal bolt holes for the seat, I'm sure it would work.
    Our current rig has vertical holes, so I'm sure the flat plate won't work (at least not without some sort of modification).
    I suppose, we could swap out to a porcelain unit but now it's more expensive and a bigger project.
  • The Blondell seat I have at home has a flat metal plate that bolts onto the toilet & then the seat is secured to that plate. It might be able to be redrilled to fit an RV toilet, but I can't say without taking the plate to the toilet to see.
  • JoeH's avatar
    JoeH
    Explorer III
    valhalla360 wrote:
    Bump....
    We are currently in thailand and the apartment has one and it is handy...but as indicated for the RV with the AquaMagic the bolt holes are on the verticle rather than horizontal like a household toilet
    Amazon has inexpensive ones for $30 but mating them to the toilet is a hassle.
    PS: Not interested in the hand held sprayer.
    I tried one of the inexpensive ones to see if it could be modified to fit either of the toilets in the motorhome and it just didn't work.
  • Bump....
