Chris_Bryant
May 22, 2015Explorer II
Keep in mind the BIRD and the disconnect are 2 separate systems, not interconnected (other than battery wise) The voltages indicated on the disconnect could be flaky simply due to a dirty switch on the panel. The BIRD simply measures the battery voltage of either battery, and connects them when the voltage indicates charging on either, with a delay built in to let the alternator get a bit ahead of the curve.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
