burlmart
May 21, 2015Explorer
bidirectional isolator relay delay and voltages
for those with motorhomes that have B.I.R.D.s, do you find that you get inaccurate or misleading voltage readings from your house battery and your chassis battery. for instance, readings that differ and fluctuate at odd rates depending on house battery disconnect toggle (STORE/USE}.
i have attempted to express some weird things i seem to encounter when doing so on this thread from the C forum. as confused as i seem here, a few years ago i went through similar issues before i'd ever hears of BIRD. to my great relief, another trail lite owner discovered we both had one in our rigs.
at this point, i am resigned to just try to ignore voltage readings and simply try to make it a point to give batteries ample shore power charge time from the parallax 7300 between RV outings.
but it would be somewhat of a relief to hear from others that a) i am not imagining things, b) i need to expect unique voltage sharing/interaction w/ the BIRD relay/delay and chassis isolator solenoid, and/or c) my system has a problem that can be tested by doing X.
i thank you for any insights and clarity.
