brulaz
Feb 12, 2015Explorer
2oldman wrote:
I doubt that 0.6a panel is doing much.
From your description it doesn't sound like you're getting a full charge (ie.. Float voltage) during the day. Don't know your battery complement.
Agree it's not doing much, but as smkettner suggests (thanks!) that's prolly because the 210AH of batts are fully charged at 14.8V by the Rogue.
So the Tiny Panel is just keeping them at 14.8 V as long as there's sunlight. (The Tiny panel is not very powerful and really doesn't justify a better/any controller.)
Now that I've turned off the Tiny Panel, after Absorb finished at 14.8 V, it took less than an hour for the batt V to drop to 13.2 V float, and it stayed in Float for the rest of the day (8 hours until sundown). Much more reasonable.
The amount of time spent in Absorb under these no-load, storage conditions is less than a few minutes. I haven't been able to witness it, and the log records it as zero minutes. The Rogue does spend more time, perhaps an hour under low light conditions in the morning to raise the battery voltage from about 12.7 V up to the 14.8 V Absorb point.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
