ktmrfs
Dec 06, 2013Explorer III
BFL13 wrote:
I think Fisherguy runs his PD9280 (non-PF corrected) with his. Probably can run the PF corrected PowerMax 100amper or WFCO 68100.
For near max load with a cold gen I recommend leaving Eco off at first, then turn Eco on a few minutes later.
I know the PD60A runs fine and gives the honda some margin, that's what I have. When I looked, the powermax PF corrected 100A should also work fine, maybe even better than a PD60A. I considered the PD80A, and couldn't convince myself I'd be able to run it at a full 80A. Problem is/was that PD doesn't spec VA draw, only watts, so it's a guessing game. I guessed it would be near the honda 1600VA max. but couldn't determine if it would be "above" or "below", so I went the the 60A.
However if Fisherguy runs his, sounds like it's an option and you've got a definitive answer. However, anything more than 80A Non PF corrected probably is going to be a problem.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
