MM49
Dec 07, 2013Explorer
ktmrfs wrote:pianotuna wrote:
Hi ktmrfs,
When I wrote PD they told me all their units are a power factor of 0.7. So the 1300 watts becomes about 1857 va. Not pretty with a genny rated for 1600 va. Then take it up above sea level. If the battery bank is truly flat with six six volts it is not going to be reliable.
The only reason it would work is if the pd doesn't zip up to full output i.e. with sagging voltage. I have seen that in person with the 40 amp pd in the RV I call home probably because the maker skimped on the wire size from the converter to the battery bank.
The person might consider solar?ktmrfs wrote:
True, the PD80 may draw about 1300 watts, but closer to 1600-1700 VA, so it's marginal on a honda 2000, right at it's continous rating. Like so many RV appliances, actual current draw is more than the "watts" rating indicates.
The PD60A draws on the order of 1400VA IIRC my measurements on one supplying 55A.
Thanks for the info and Wow, Looks like the PD80 is worse than I thought for draw!. I see why it requires a 20A circuit.
Sure am glad now that I went for the PD60A instead of the PD80. It's fine with the honda 2000 and my bank of 4 GC even at altitude. But it does give the honda a workout.
If I really need to "poor the coals" to the batteries, I dig out my second honda, parallel them and fire up the PD60 in the pass through and the PD55A in the panel and hit the batteries with about 110A. That combo will hold high current for quite a while before it starts to sag.
Good to hear what is really working. The modern inverter generators do one thing perfectly; they protect themselves! It wold be a shame to buy all this high price equipment and find out that the generator kicks out because of an inductive load spike. The real test is Joe consumer using it. My application is a PD9140 w charge wizard with a Honda Eu1000i against a group 27, 12v batt. Then gen runs at about 1/2 throttle Let's hear what people are using!
MM49
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
