ScottG
Mar 21, 2018Nomad
3 tons wrote:
I have a BD vector and have found that it often will shutdown on even a moderately discharged battery...The solution was to charge the battery a bit with a dumb 40 yr old craftsman charger, then switch back to the finicky ‘smart’ (or is it really dumb?) vector charger for the finishing charge - works every time, but became too much bother to have to deal with...So now I use a TRULY Smart Optimate model 6, diagnostic charger which will do the job every time no matter what....IMO, a better way to go...
3 tons
You may have had the same caps blow that went in mine. They could trick it into thinking wrong.
