CJW8's avatar
CJW8
Black painted slide out walls extremely hot
My slides side walls are painted black on the outside. When the sun is on them they get too hot to touch. On the inside, the surface temperature of the wall can get to over 100 degrees. It makes my couch uncomfortable to use. It is like there is a large radiant heater aimed at you. I decided to try and do something about it. I had a roll of 1/4" thick foil sided bubble wrap that I cut to fit and place it on the sunny side of my slides. The inside temp went from 100F to 82F and it is still going down. My refer is in one of the slides. I'm sure it will be happier. AC's were running continuously, now they are cycling. Here is a pic:
  • The bubble foil does a good job and working with it is easy. But, why not just paint the black area with white or silver paint?
  • I am parked for awhile and yes, it'll have to be removed to retract the slides. It is friction fit so it can be removed in minutes. In the future, I'll paint the walls light gray which is the primary color of the RV.
  • A buddy of mine had prewarned before I bought my TT so it effected my choice and we chose a unit that had light color slides. Your solution is brilliant. I hope it works for you long term. Please let us know.
  • It's a good idea, but will the slide seals interfere with it or pull it off? If you park someplace for the winter, it could be worthwhile to replace it every so often. In our case we move every three to four days. Since installing the bubble wrap, how may times have the slides been in and out?
    Bill
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
