Cummins12V98
Sep 11, 2019Explorer III
There is a tool to cut old pipe out of a ABS fitting. Don't think you want to spend that much $$$.
If you have a bad glued in valve simply buy the same open it up and remove the center slide portion and seals and install in old valve.
