wanderingbobExplorer IISep 11, 2019black plastic waste pipeThree inch plastic waste pipe , is there a way to unglue it or must you cut and start over ? The valves can you buy a rebuild kit ?
ScottGNomadSep 11, 2019If you just need a valve, no cutting is required. Simply buy a new valve, unscrew the 4 small bolts and slide the new valve portion in. You'll end up with extra pipe connections that you don't use. You need something like this: 3" valve
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentBlack Water waste valve leakingBlack Waste Tank BypassBlack waste tank connection question...Tornado flush added to black waste tank...(Leak!) Toilet plumbing connection to Black Waste tank...
