The_Kunkels's avatar
The_Kunkels
Black tank bound up.
Our black tank won't pump out. The fellow in the park said he got nothing out. When ya look down the toilet it is not empty. Thanks.
  • The Kunkels wrote:
    The tt is stationary. 35' Hornet Keystone.
    Hate to say it, but you got a problem unless you can dump on the ground or hookup a blue tank.
    You really can't blast a blockage away without being hooked to sewer. Guessing the RV tech isn't going to want that job either.
    If you're not living in the rig then I would put some Rid-X in it and wait a week then try a pump out again. Prior to that make sure your gate valve is working correctly.
  • Vacuum truck..septic/honey wagon truck
    If it can't empty the tank then dump valve is NOT opening.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
