- Old-BiscuitExplorer IIIVacuum truck..septic/honey wagon truck
If it can't empty the tank then dump valve is NOT opening. - SidecarFlipExplorer IIINothing beats a coagulated poop pyramid...
- John_JoeyExplorer
The Kunkels wrote:
The tt is stationary. 35' Hornet Keystone.
Hate to say it, but you got a problem unless you can dump on the ground or hookup a blue tank.
You really can't blast a blockage away without being hooked to sewer. Guessing the RV tech isn't going to want that job either.
If you're not living in the rig then I would put some Rid-X in it and wait a week then try a pump out again. Prior to that make sure your gate valve is working correctly. - hawkeye-08Explorer IIIIt is fun reading all the posts that mention driving around for an hour when the unit is a stationary one at trailer park.... valve is only open when dumper pumper is there to suck it out since there are no sewer connections at the site.
- Ralph_CramdenExplorer II
greenrvgreen wrote:
Don't bother with chems or flush wands. And instead of a broom handle go to Ace and get a four-foot steel rod. STick this down the tank and use it as a stir-stick while you leave the flush going. Does anyone need to ask how I know this works?
Keep stirring and watering until your pyramid of goodies melts away and begs to be flushed. And, careful with the used rod.
I NEVER use enough water, I eat WAY too much cheese, and as a kid Mom was always yelling at me to flush the toilet after I used it. I took all these skills with me into RVing, and the only reason my toilet hasn't been raised two feet off the floor is that I stir before dumping.
Look, it's a lousy task to begin with, and I'm lazy.
I believe the correct terminology for that procedure is turd herding. - greenrvgreenExplorerDon't bother with chems or flush wands. And instead of a broom handle go to Ace and get a four-foot steel rod. STick this down the tank and use it as a stir-stick while you leave the flush going. Does anyone need to ask how I know this works?
Look, it's a lousy task to begin with, and I'm lazy. - flylipsdaddyExplorerA Bag of ice and bottle of DrainO and an hour drive...
- PipemanExplorerIf it is a pyramid, you could use RV Digest-it to dissolve the mound. Pour a whole bottle of it in and it's supposed to dissolve everything within 24 hours. I use it in my tank along with water softener, two caps of liquid detergent and a toilet bowl of water. "Water is your friend" . The tank is slippery from the softener and really doesn't smell that sweet from the laundry detergent but what the hey.
- Bill_SatelliteExplorer IIPick up one of these.
http://www.campingworld.com/shopping/item/rv-hydro-flush-45-degree/14496
It will allow you to connect a hose to that connection that will shot water backward up into the tank. If the valve is stuck closed the water will not be able to go anywhere. If there is a blockage of some kind this will push it out of the way. You will need to have the truck there or cap the outlet as if this clears the blockage you will experience an undesired experience very similar the the movie "RV". - myredracerExplorer IIOne thing you can try is get a stiff rubber type hose and cut it so you have 8' or so and push it back into the tank and turn the water on to try and break up the blockage. Must have someone watching inside so toilet doesn't overflow. Can also push the hose into the toilet. Gloves optional... :E May need to buy a hose. We had a badly plugged tank on a previous TT and the honey wagon operator had an old rubber hose laying around and pushed it into the outlet pipe to flush it.
Occasionally, when the factory cuts a hole in the tank for the outlet pipe, the disc gets left behind and can plug the outlet.
For a deep cleaning that will get the tank back to factory fresh, factory clean, Liquid Drano can be used. Our owners manual says to use it. Won't hurt metal or plastic. Have used it a few times. Need to drive around so it sloshes inside the tank. Just don't dump it into a private septic system.
One of the biggest mistakes with black tanks is skimping on water. You need to add 3-5 gallons after each dump and before using and then adequate water at each flush. Makes a surprising difference in how long you can get between dumps and how much easier it is to rinse/flush. Dump valve must be always be closed except when dumping.
Make sure to thoroughly flush the tank after each dump. If you don't have a built-in rinser, you can try a back-flush elbow or inserting a flush wand into the toilet.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
