DavidP
Nov 04, 2014Explorer
Definitely a chitty job. As long as you have easy access to the knife valve for replacement it should be pretty easy. Aside from the obvious of making sure the tank is empty I would also make sure it was flushed out and cleaned as good as you can get it.
