John_Wayne
Nov 05, 2014Explorer II
Some have mentioned to use thin metal sheets on each side of the new valve when sliding it between the fittings to keep the seals in place when you slide the new valve in. Line every thing up pull the metal sheets out insert bolts and nuts and done.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
