drillagent's avatar
drillagent
Black Tank Issues
When we purchased our used 2012 Montana 3750FL, DW and I took it out on a shakedown cruise. There were a couple of issues that were easily fixed, so no further problems there. But when I emptied the black tank, I noticed there was still fluid and some solids still in the bottom of the tank. I flushed the tank several times using the built in tank flusher. Weak flow by the way. Even after I stuck a hose down the toilet. I even filled it with a 5 gallon bucket to verify the capacity. There's always fluid and gunk left over. I can't seem to get everything out. You may find this gross, but I even taped my iPhone to a yard stick, turned on the video camera, and stuck it down the toilet to see what was down there.
So after reviewing the tape, I noticed that the tank empties at the side, right below the toilet. And right in front of the hole, there seems to be a bulge in the tank. Right below the toilet where everything drops. It's about 1/4 inch below the level of the drain pipe. The rest of the tank drains just fine, but there's always this large puddle of nastiness left over.
Just to be clear, my intent is to NOT leave the tank completely dry. I generally pour in a five gallon bucket with RV RidX and Calgon after I flush the tank. But I'd love to be able to get all the nastiness out before I do that.
Is this an inherent problem with all black tanks, or is it just mine? How do I get rid of the bulge/puddle? Is this something I need to take to a dealer to fix, I can fix myself, or am I just up a puddle without a paddle and have to live with it? Thanks in advance for any help.
  • You have a Poo pyramid. Most likely from using it with the valve open. Fill it to over half full, and let soak to soften and break up. Drive around awhile, curvy roads are best to slosh/agitate it around to break it up. Dump and repeat as needed. It may take several times to fully get it cleaned up. Filling it to about a 1/4-1/3, add a half of a small bottle of dawn to it, and dumping 20 pounds of ice in it, before driving it around will also help break it up. If it is pretty solid, a good soaking first will help greatly. When clean after dumping, put in at least 5 gallons of water with your treatment for best results. Never be stingy with the water when using either.
  • Tvov's avatar
    Tvov
    Explorer II
    Sounds like maybe your black tank has a factory defect? Only fix I can think of is replacing it.
    My black tank (on a 21ft TT) can be rinsed completely, all solids cleaned out, if I take the time to do it.
  • Frankly, you don't want it to empty completely. You always want some liquid in the tank. You should not get any bad smells. A bit of liquid in the bottom will help to keep the solids flowing when you drain the tank.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
