Nomadac
Aug 24, 2014Explorer
Dutch_12078 wrote:
I've installed the SeeLevel II external capacitance tank sensors and display system on each Class A we've owned, and found them to be reliable, accurate, and relatively easy to install. The percentage readouts give a much better picture of the tank status than the "Empty, 1/3, 2/3, Full" systems common to the "screw through the wall" sensor systems.
X2 We have the SeeLevel system that gives the reading in %filled, i.e 23%, 45%, etc. than you use the tank capacity to determine the gallons in the tank. When my tanks are empty they read 0%.
This is the only accurate system to have IMO.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
