Nomadac
Aug 24, 2014Explorer
Dutch_12078 wrote:
I've installed the SeeLevel II external capacitance tank sensors and display system on each Class A we've owned, and found them to be reliable, accurate, and relatively easy to install. The percentage readouts give a much better picture of the tank status than the "Empty, 1/3, 2/3, Full" systems common to the "screw through the wall" sensor systems.
X2 We have the SeeLevel system that gives the reading in %filled, i.e 23%, 45%, etc. than you use the tank capacity to determine the gallons in the tank. When my tanks are empty they read 0%.
It also gives battery voltage, propane tank reading, fresh water, black and gray tank readings, that are all very accurate.
This is the only accurate system to have IMO.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
