mnoeltne
Jul 07, 2019Explorer
Acampingwewillgo wrote:
Just for kicks, do you use LOTS of water when flushing the throne! Not speaking of while cleaning but rather in just the everyday flushing the toilet. I know I will always fill the bowl fairly well before stepping on the pedal to flush. I realize if you are someplace without sewer then doing this might fill the tanks quickly.
We try to, although that is part of the reason I'm changing the blade seal. Usually there isn't a whole lot of water in the bowl, but we do hold the flush lever open to let more water down in there.
So, I'm sure that this at least part of the issue, but the rough texture of the surface is certainly not letting stuff run off down into the tank easily.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
