DFord
Jul 07, 2019Explorer
Never BUT NEVER! camp with your black tank drain open!!!!!!!!!!!
ALWAYS!!!!! Allow the black tank to fill to almost full before dumping!!
IF YOU CHOOSE NOT TO FOLLOW THESE STEPS, YOUR SOLIDS WILL MOUND UP!!!
Just like you're describing here. After flushing the tank ALWAYS allow it to fill with enough water to cover the bottom of the tank to prevent the next toilet flush from sticking to the bottom of the tank.
If you follow these hard and fast rules, you will not have any problem with mounds of solids and TP building up in your tank.
RVs are not flush toilets like you have in your house where over a gallon and a half of water move the solids along towards the septic tank or sewer treatment plant with each flush.
I use and recommend HIGHLY a tank treatment called "HAPPY CAMPER" every time I empty my tank. It helps dissolve TP and breakdown the solid but most of all kills the odors. After flushing the tank, fill the bowl, put a scoop of HAPPY CAMPER in the toilet and use your bowl brush to swirl it around to mix it up and clean the inside of the bowl and lip wiping off any excess. Then flush the toilet, fill it again to rinse your bowl and brush before putting thinks away and returning the toilet to use. http://1-happycamper.com/ Use this link to read more about the product. You can find it offered by several vendors on the internet, Amazon and Ebay plus "good" RV supply stores. Shop around.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
