Bobbo
Jul 07, 2019Explorer III
Old-Biscuit wrote:
Typically waste tanks are sloped...shallow end under inlet pipe.
Whenever using TP you should FILL the toilet bowl FULL prior to flushing so you have good volume to carry stuff away from inlet area
Just the nature of gravity toilets.
Shorter the drop the more likelihood stuff will collect if NOT using enough water when flushing
maddog348 wrote:
If NOT really full before using ~ do your thing ~ hold pedal down 1/2 way (lets water in none out)~ fill to top with water ~~ FLUSH
These are the answers. Whenever solid waste (including just TP) is in the toilet bowl to be flushed, FILL THE BOWL TO JUST BELOW THE RIM BEFORE FLUSHING. That volume of water will carry the TP right past the "splash shield."
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
