mnoeltne's avatar
mnoeltne
Black tank splash shield problem
I assume it's a splash shield anyway.
When we flush our toilet in the motorhome (Thetford Aqua Magic V) things go on down for the first day or two of a trip. Then paper and stuff starts to build up and it won't flush entirely.
I pulled the toilet today to install a new blade seal, and what I see seems to be a splash shield just below the drain pipe. It looks like things are supposed to flush down there, then drain off to the sides into the tank. But instead the TP builds up on this surface. We use the TP that's supposed to dissolve easily, but since it's up on this shield it isn't submersed in water and doesn't dissolve.
I can get everything to move if I use a cleaning wand (like this Valterra wand), but that's a hassle and uses a lot of extra water when we are dry camping.
Any suggestions for handling this problem, other than somehow removing the shield?
I guess I could take a hole saw down through the drain pipe and cut an opening in the shield, but I'm hoping for a better way.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
