- LadyRVerExplorer III spray the rod on pull handle with silicone spray every couple of months. Makes a big difference.
- ernie1Explorer III had a similar problem repeatedly until I found out that as I would change the seals or sometimes the entire valves, I would lube the seals and surfaces with vaseline or plumbers grease. This was recommended by the manufacturers and people on various sites. This was the problem: petroleum products will degrade rubber type products making them soft and spongy. In my case, the seals were swelling and would cause it to drag as the valves were being used. Now I only use silicone products like plumbers grease that is SILICONE based and not petroleum based. Have not had trouble for years since.
- MDKMDKExplorerTry reducing fibre in diet, and increase Omega 3 fish/krill oil.
- 2oldmanExplorer III'm not sure, so I direct you to a few youtube posts.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
